Timing belt change on '95 3.4L V65000fingers 06-18-2008, 12:45 AM I'm curious to know how daunted I should be about changing my own timing belt on a '95 Taco with the 3.4L engine. I changed the belts in my old Volvo 240s and it wasn't too bad of a job, kind of fun in fact. Am I right in assuming that the Tacoma's timing belt change is a bit more complex? Is it still do-able for the weekend warrior, like maybe a 5-6 hour job? Flash75 06-18-2008, 06:17 AM Where is my 3.4 06-20-2008, 12:33 AM Hello if your to change the timming belt change the water pump and make sure the cam seals are not leaking , Too change the belt and water pump is only 3 hr not to bad good luck vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
