Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Beetle - Air Cooled > Type 3
Old 06-17-2008, 05:02 PM   #1
DAB77
DAB77 Normal reputation
73 Beetle no idle
A friend got a 73 Beetle a while back, ran great. Yesterday it started stalling at stops, if he keeps his foot in it, it will stay running. He brought it by today to have the idle turned up but there is not enough screw to do the job.Does anyone have any ideas? I haven't done anything with VDUBs since 1979 and don't remember a whole lot from back then.
DAB77 is offline   Reply With Quote
Old 06-17-2008, 09:00 PM   #2
DAB77
Re: 73 Beetle no idle
found the air mixture screw,,,that took care of it
Old 09-17-2009, 05:42 AM   #3
dgee
dgee Normal reputation
check carb see if the wire on the carb is attached for the stop idle solinoid if it is then pull out solinoid attache wire back on and see if the solinoid works by turning on ignition switch on. if not working there is you problem.
dgee is offline   Reply With Quote
Old 10-10-2009, 11:52 PM   #4
Doug Rodrigues
Doug Rodrigues Normal reputation
Send a message via MSN to Doug Rodrigues
Also, that electric fuel cut off on the carburetor has a habit of working loose and elongating the hole. Before that happens, use locktite on the threads to keep the thing from working loose. Once the thing comes loose, and the hole becomes elongated, you're screwed. Maybe JB weld might be of help later, IF this happens to you.
Doug Rodrigues is offline   Reply With Quote
Old 10-21-2009, 05:48 AM   #5
NY_SouthernComfort
NY_SouthernComfort Normal reputation
Maybe a good tune-up and replace the fuel filter.
NY_SouthernComfort is offline   Reply With Quote
Bookmarks
Google
Web AF
