Driving home the other day my truck cut out when I was driving it at around 55 MPH. I pulled over and tried to restart but it just turned over. I have power and gas.
Did it just die on you, I mean, it didn't sputter but something like turning your ignition off? Turn your ignition on and see if you can hear the electric fuel pump run? If not check fuel pump collision switch. Also check if you are getting spark to your plugs. Of course other things may cause the problem but check the basics first.
