Fuse Relay locationsprucebingsteen 06-17-2008, 12:38 PM 98 Grand Voyager 3.3L..... I know the fuse panel is undeneath the dash by the brake pedal, but can anyone tell me what Relay #10,11,12, 13 are ??? thanks to all ! Bear 06-17-2008, 01:45 PM You should also have a power distribution box under the hood, drivers side with fuses and relays and all are marked on the cover of the box. RIP 06-17-2008, 04:42 PM Sure you want the ID on relays? None of my schematics have the relays ID'd by a number. Fuses yes. Relays no. sprucebingsteen 06-17-2008, 05:53 PM Actually what info I was looking for was the larger "fuses"? underneath the dash board. I recognize the smaller ones all in a row but not the 2 that are a bit bigger above. 1 is in spot #10 and the other is spot# 11 RIP 06-17-2008, 06:09 PM The schematics don't show the physical size but fuse #10 should be a 10 amp fuse for the starter relay and fuse #11 should be a 20 amp fuse for the rear heater/AC unit. Does that make sense with what you are looking at? Automotive Network, Inc., Copyright ©2012
