93 s 10 Blazer - where is on/off 4x4 switch??
Google
Web AF
SteVB
06-17-2008, 08:49 AM
i have a 93 s 10 blazer with electronic 4x4 fully loaded & i have no clue where the 4x4 on/off switch is, the truck went into 4x4 by itself when i backed out the driveway & i have NO IDEA where the on/off switch is.i cannot turn off the 4x4. all i see is a 4L / 4H rocker switch above the headlight switches.
MT-2500
06-17-2008, 09:49 AM
What transfer case?
On the rocker switch.
Any lights on it.
There is a combination to the switch that I do not have right now.
Try pushing 2W a couple of times or holding it down a couple of seconds.
Got your owners manual for it.
MT
SteVB
06-17-2008, 10:10 AM
thanks for the reply...
i have no idea which transfer case it is,or IF there are different ones. would that make a difference????
it`s the top of the line fully loaded LT 4x4 model with the vortec engine & automatic. no, we bought it without the owners manual. I would have looked in there first had we had one.
SteVB
06-17-2008, 10:17 AM
What transfer case?
Any lights on it.
MT
there is no "2W" on the rocker switch, there`s only 4H & 4L. THAT`S the problem- i don`t know where the ON & OFF switch is. thanks.
MT-2500
06-17-2008, 10:58 AM
Do not drive it on dry payment in 4W.
Transfer case ID is on back of transfer case.
How do you know it is in 4W?
Any lights on the switch?
Any little green dots light up?
As said there is a certian push button cobination to change it.
I will do some more lookng tonight for the shift cobination.
Or a All dat online sub should have it.
http://www.alldata.com/products/diy/index.html
Try pushing both at same time or pushing one at a time a cople of times.
Slayer0420
06-26-2008, 01:47 AM
Push the 4H switch to change back and forth between 2H and 4H.
Put the transmission in netural and push 4L to shift into 4L.
Leeann94astro
06-26-2008, 08:20 AM
https://www.mygmlink.com/pdf/go2content/manual/US/en/chevrolet/1994blazer.pdf
It's a '94 manual, but has the correct stuff for the electronic controls.
Google
Web AF
