Re: 99 contour strut into steering knucle
What you should have done is removed the brake caliper assembly, then the tie rod, then the sway bar link, then removed the steering knuckle from the lower ball joint. Now, swing the a-frame down as low as it will go. Attach something to it to force it to stay down. Now, place the steering knuckle into the strut. You will probably have to force it back into place by using two bottle jacks, one on either side and a piece of flat metal stock between the two. Use a hammer to tap on the knuckle as it presses into the strut.
Once the strut is in place you can tackle the CV Joint which has been lengthened. Move the joint back and forth using the rotor. When you feel the little balls inside the cv joint are lined up....give it a swift kick with both feet. This will shove it back into place and gain you those precious inches you had lost which didn't allow you to line up the knuckle with the strut. Now maneuver the lower ball joint back into place, its tricky but once you slowly loosen the pressure that is holding down the A-Frame you will get it.
Trust me, the next one you do will only take you about an hour.
Vince
