Re: 97 contour knocking
You've spun a rod bearing. A 'somewhat' common problem with the 2.5L duratec. Most people run about 6.5 qts of oil in this motor to compensate for the oil starvation.
If you want to fix it, you can replace the 2.5L block with a used one or do what most people do and swap in a 3.0L. Both are about the same price.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
