Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 06-16-2008, 10:17 AM   #1
MJBJimmy2000
MJBJimmy2000 Normal reputation
Jimmy 2000 front power windows stopped working
Hey Guys,
I did a search on this website and others and couldn't find the answer to my issue.
The 2 front power windows suddenly stopped working. The rear two are fine. The fuse inside the car is fine. Is there another fuse in the engine compartment? Any other ideas what the issue could be? I would think it unlikely that two motors went simultaneously but what do I know.
The Jimmy has been stood outside in the hot florida sun for a few weeks. That's the only unusal circumstance I can think off.
Thanks in advance for any help you can give.
- Mark
MJBJimmy2000 is offline   Reply With Quote
Old 06-16-2008, 06:55 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: Jimmy 2000 front power windows stopped working
Power to windows come from a circuit breaker in body relay block behind left side dash.
Does the rear windows work from master switch?
Pull master switch and check switch operation.
MT
MT-2500 is offline   Reply With Quote
Old 06-17-2008, 02:53 PM   #3
MJBJimmy2000
Yes rear windows do work from the master switch, by that I assume you mean set of switches on drivers door?
Old 06-17-2008, 03:43 PM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
Ok you are getting power to master switch.
Pull out master switch and see if it is switching power and ground to your front window motors.
MT
Bookmarks
Google
Web AF
