22RE with MegaSquirt
Google
Web AF
chacaman
06-16-2008, 09:24 AM
Hello Guys i need help.
i want to install a MegaSquirt ECU To my 22RE
and i need help for identifie IGT and NE signal in the Ignter Module
for Connect The ECu
some body can help i have pic of inside of the igniter Modulehttp://memimage.cardomain.com/member_images/11/web/2975000-2975999/2975227_53_full.jpg
fourwd1
06-16-2008, 12:01 PM
According to a diagram I have the IGT wire should be blk w/a white stripe and the NE should be blk w/a red stripe.
fourwd1
06-16-2008, 12:03 PM
Also, those colors would typically be the harness side. Wires on a modules "pig tail" may not be the same.
chacaman
06-16-2008, 02:17 PM
ok, if you see the connector between the Igniter module and the Wiring Harnes and see what color is connect to the IGT and NE signal
in the igniter module side ?
for example
the IGT BLK w/a White Stripe is connect to Blue Wire in the module
and the NE blk w/a Red sctrip is connect to Green cable in the module?
can this help
thanks guys i buy a truck with out engine and wiring harnes
i buy a kit MegaSquirt and i installed but i need find the NE and IGT signal from the igniter..
only have the igniter tnks
Google
Web AF
