Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 06-15-2008, 11:40 PM   #1
quickstart
quickstart Normal reputation
1997 Jeep Cherokee Sport - Won't start
Our 1997 Jeep Cherokee Sport cranks but won't fire. Recently had distributor replaced and since then hasn't started. No fuel gauge, voltmeter or engine light. Security key light stays illuminated. Any suggestions??
quickstart is offline   Reply With Quote
Old 06-16-2008, 01:16 AM   #2
Bobbywolf
Bobbywolf Normal reputation
Re: 1997 Jeep Cherokee Sport - Won't start
Sounds like a fuse is gone. Failing that, possibly the ignition switch is shot. If it was just sudden like that, my bet is a fuse. Check the big guys under the hood to start.
Bobbywolf is offline   Reply With Quote
Old 06-16-2008, 07:59 PM   #3
fredjacksonsan
Sir...I AM a professional
fredjacksonsan's Avatar
fredjacksonsan Normal reputation
Send a message via AIM to fredjacksonsan
Don't forget to look at what you just replaced, since replacing it started the problem. Also, check anything in the area in case you bumped it.
AF's RULES can be found HERE -- Please read them.
fredjacksonsan is offline   Reply With Quote
Old 06-20-2008, 07:50 PM   #4
wwwildman
wwwildman Normal reputation
Did you connect the electrical connector at the distributor? you may not be getting a signal to/from the stator or cam sensor.
wwwildman is offline   Reply With Quote
Old 06-23-2008, 11:01 AM   #5
c180
c180 Normal reputation
Hi, If you disconnect the Crankshaft Position Sensor, fuel gauge, voltmeter or engine light, etc, will function. Then change Crankshaft Position Sensor, this is typical of models from 97 to 02.
c180 is offline   Reply With Quote
Bookmarks
Google
Web AF
