Replacing Shocks on 2001 4X4 EdgeDenver1911 06-15-2008, 06:35 PM My truck (140k miles) has begun to have quite a bit of bounce in it that doesn't settle quickly. I am going to replace shocks. I've done rear ones before on a 1994 ranger (easy), but haven't even looked at the front ones. Any advice on what shocks to get (front and rear) for a more cushy ride? Also, can a semi-skilled DIYer replace the fronts? Any special tricks? Thanks, Denver backerm1 06-15-2008, 08:17 PM replacin shockes is easy, easy, easy. depeniding on what type of driving you do, your choses are endless. whether it be off road, mud, or highway. besure and get a shock that performs to your driving terrain. you can also opt. for an adj. shock if you wanna take your rig to the trail. Denver1911 06-16-2008, 07:36 PM replacin shockes is easy, easy, easy. depeniding on what type of driving you do, your choses are endless. whether it be off road, mud, or highway. besure and get a shock that performs to your driving terrain. you can also opt. for an adj. shock if you wanna take your rig to the trail. Thanks backberm1, but ... How do I match shocks to my driving style? I've seen basically two type ... standard and heavy-duty. I drive about 500 miles per year on gravel, with several trips on mud, dirt, cow pastures, etc. However, as with most people, my pick-up takes me to and from work mostly. I would imagine that the heavy-duty shocks would hold up better to the bouncing on gravel roads, etc. However, would my on-road comfort suffer? I want to get the best value also. I was looking at the Bilstein HD shocks available locally. Thanks, Denver backerm1 06-16-2008, 11:15 PM your truck is a 4x4, so its gonna come from the factory with a mild off-road shock. yeah the heavy duty shocks will handle off-road better and not get as mushy as they heat up. I've seen some externally adjustable shocks in some stores, they might have to special order them. Denver1911 07-24-2008, 07:14 PM Alright then ... I did it. I put in some Bilstein HD shocks I ordered from Autozone (that's another story ... do their order fulfilment & customer service people not have a clue or what?). My truck is a whole new ride. The harsh hits are much smoother and damp quicker. The truck doesn't dive when I take hard corners. The slow bumps are much smoother. Glad I did it and it was extremely easy to do. But ... I've still got quite a bit of jiggle. It feels more like a front-to-back or side-to-side jiggle instead of an up-and-down bounce. Any thoughts on what might cause this or how I might get it to go away? Thanks, Denver backerm1 07-25-2008, 06:38 PM yeah where i used to live the autozone was full of idiots who didn't know a battery from a brake pad. the one here is real good though, alot of them ASE certified and real helpful. what suspenspon you got on that truck? torsion - leaf? Denver1911 07-25-2008, 09:30 PM Backberm, I've got the torsion bar suspension. Would that be the source of my jiggle/bounce? I know I need a front-end alignment because my front tires were wearing pretty hard on the inside edge plus I just had a new tie-rod end put in. Could that cause any weird, irregular vibration? My issue with Autozone was their internet ordering dept. I didn't go to the store, but ordered online. They shipped the fronts for a GM, I requested the right ones, they sent ONE replacement. I called back to request a second one. They called 4 days later to say it had shipped. It hadn't showed up in 5 days, so I called to inquire. They said it "shipped out yesterday" and I would have it Monday, 3 days later. It hadn't showed up by Tuesday so I called and they had no record of it ever shipping ... nevermind that they told me it had shipped twice already. They shipped it out that day and I had it the next. Later backerm1 07-26-2008, 05:09 PM If you just had a tie rod put in and did not get an alignment then I think that is your problem. Tell them to look it over real good too. might be warn buscings too. Denver1911 07-26-2008, 05:42 PM I didn't get an alignment at the time because the mechanic that did it doesn't have the setup. I had him look everything over real good and he found nothing else. I totally trust this guy and have for years and years. I'll get my tires and an alignment in a few weeks and see what's up. Thanks. Automotive Network, Inc., Copyright ©2012
