1977 coupe deville 425 dies under load....poppo2_4 06-14-2008, 09:51 PM Hello guys im new to this forum and so far its great........ just reently My car loss power, and dies when i put it in drive now i changed every new holley car fuel pump alternator intake cleaned and new gasket cleaned fuel tank checked vac lines new distrubitor and super coil new 10/40 oil etc im loss now im guessing fuel pressure or lock up convertor but the car tries to stay running when i put it in drive and give it gas JUST NO Power DFBonnett 06-15-2008, 08:57 AM If in neutral or park, what happens if you suddenly floor it? Does it bog? poppo2_4 06-15-2008, 11:17 AM Whats up , its great in netural and park but once i put it in gear and i hit the gas it doesnt even want to do anything and stalls out, and if i floor it thats worst..........maybe the timing is set right cause if u think about it if it dies in drive , so if i floor it in drive the power from the motor should just go.............do u know the fuel pressure for these motors 95 9c1 06-29-2008, 02:43 AM I've had a few of theese cars still have one, fuel presure stock pump 5 to7 psi, in 77 they had thm400's no lock up tranny's. What kind of vacum do you have at idle? it should be 15 to 18. I recently had this same problem it turned out to be a massive vacum leak. Theese motors are very sensitive to timing,tyring to get more power by advancing the timing is not the greatist thing for theese motors they are also sensitive to retard also,I would go no more than 1 degree in either direction from stock setting Also the tin intake manifold gaskets can fool you they have a tendency to split between cylinders and on the ends. although this is more common with the factory aluminum intakes, but i did have it happen on an iron intake [creates massive vacume leak that can be hard to find] Good luck hope this helps a little maxwedge 06-30-2008, 02:48 PM Disconnect the engine pipe from the manifolds, see if the Cat is blocked or even the muffler. Automotive Network, Inc., Copyright ©2012
