Re: Brake lights
You also want to be 100% sure you have the right stop lamp switch. I had a friend with a 94 with the same thing, switch tested good, was properly adjusted, and still same thing. He brought it to the shop, I looked, and it all looked good, but same problem. Then I looked a bit harder and found he was adjusting the switch for the cruise control, that on his 94 the cruise and the stop lamp switch were 2 seperate animals. I am not sure if the newer one is the same. but it wouldn't hurt to look a lil further up on the brake pedal arm to see if there is "another" switch.
