94 Ford Ranger - Not startingauggie01 06-12-2008, 08:53 PM The last 3 years my 94 ford ranger will just not start..If you let it sit for a few hours it will start back up sometimes it does take a jump. Then it won't do it for a few months then it will do it once again. It has happened about a dozen times in the last three years. Recently had a new battery and new starter also with spark plugs and wires. If anyone has had this problem or knows what it might be or some ideals on what to try. Thanks Auggie01 Davescort97 06-15-2008, 12:01 PM Welcome to Automotive Forums. Sounds like you have an intermittent drain of the battery. I say once in a while because it it was ocurring all the time it would be a predictable thing. I think you might not have shut a door or the trunk completely and the dome light might have caused the battery to drain. If this isn't the problem you could hook up a light or DVOM between one of the battery terminals and the cable. If the light comes on or the DVOM registers current something is causing a drain. To find out what, make sure the key is off and no dome light or trunk light is on and pull fuses until the light goes out. This will tell you what electrical system is draining your battery. backerm1 06-15-2008, 05:00 PM which codes are present? Automotive Network, Inc., Copyright ©2012
