98 Neon Air Conditioning Recharge...help.
Inascent
06-10-2008, 02:22 PM
OK everyone, My Neon's Low Service Port for which to attach the Air Conditioning Recharge Hose does not recieve any R-134a Into it properly (FROM CAN), and all the chemical leaks out even after making sure it is properly attached:confused: ... I do not know what the problem is:banghead:... it just keeps shooting out even though I made sure the connection was placed straight on.... :shakehead
MAYBE I AM CHECKING WRONG OR IS THIS A PROBLEM ANYONE ELSE HAS HAD... BUT IF ANY OF YOU CAN LEAVE A SUGGESTION THAT WOULD BE APPRECIATED :2cents:
THANK YOU :biggrin:
99 Neon R/T
06-22-2008, 10:22 PM
I dont want to insult you but are you sure you have the low side port?If so could your schrader valve be bad?
perez3
08-05-2008, 04:11 PM
first time i did it, the can was full at first, we place the end of the tube over the input hole thing, lift up the plastic at the bottom of the tube plug as your putting it on there, then the plastic springs back down and locks over it
second time i tried though i got pressure maxed out and had to disconnect, then got no pressure so maybe u need a new can
