Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 06-08-2008, 06:49 PM   #1
lee756
lee756
engine cuts out at 3800 rpm
1997 Grand Prix SE 3.8L
Engine cuts out at 3800 rpm, reving in neutral or while driving.
Changed Spark plugs, new plug wire set, all coils within accepted range of 5-7K
Check engine light will come on and then go off - It may not cycle back on for several weeks--not sure if this is revelant.
where do I go next?
lee756 is offline
Old 06-08-2008, 08:03 PM   #2
GTP Dad
Pontiac Guy
GTP Dad Normal reputation
Re: engine cuts out at 3800 rpm
Revving in Neutral you are probably hitting the rev limiter on the PCM. This is normal. It is not normal for it to do that in Drive. I suggest you get the computer scanned to see if there are any stored codes. If not then you may have a problem with either a bad PCM or a fuel shortage issue. I would bet on the PCM having an issue. It is possible that it may need to be replaced.
GTP Dad is online now
Old 06-08-2008, 10:18 PM   #3
tblake
AF -Advisor
tblake's Avatar
tblake Normal reputation
By "engine cuts out" do you mean stalls or do the rpm's just not increase further?
2000 Pontiac Grand Prix GTP
(3.5" Pulley, DHP 1.0 PCM, ZZP 2.5" High Flow Downpipe, MMS Ported and Polished Lower Intake Manifold, ZZP Stage 1 Ported Throttle Body, 180° Thermostat, NGK Iridium TR6IX)
Check these videos out guys! (Good Stuff)
Honda Cog Commercial
Peter Griffin Fart Cover-Up
tblake is offline
Old 06-23-2008, 09:22 PM   #4
lee756
lee756
Found the problem- for the second time the intake manifold gasket has blown. Replaced upper and lower gasket, intake plenum and there you go
GM has yet to properly handle this issue.
lee756 is offline
Old 07-29-2008, 04:46 PM   #5
buckeye5889
buckeye5889 Normal reputation
my car has the same problem, the rpm's dont want to go any higher when I am driving though. I have to let up on the gas and try again any ideas?
buckeye5889 is offline
Old 07-29-2008, 09:26 PM   #6
BNaylor
BNaylor's Avatar
BNaylor +50
Originally Posted by lee756
Found the problem- for the second time the intake manifold gasket has blown. Replaced upper and lower gasket, intake plenum and there you go.
Since the OP has resolved his issue this thread has been closed from any further discussion/replies.
'08 Pontiac Grand Prix GXP - LS4 5.3L V8
'01 Buick Regal GS - L67 Series II 3800 V6 Supercharged
'97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline
Old 07-29-2008, 09:29 PM   #7
BNaylor
BNaylor's Avatar
BNaylor +50
This member has a post at this thread concerning his issue.
Click here
Timeslip 08/12/06
BNaylor is offline
Closed Thread
Bookmarks
Google
Web AF
