Strange AC Happening
robroy55
06-07-2008, 05:48 PM
Hello Folks,
I have a 2002 24V with 42425 on the clock. Yesterday, I went to Home Depot, came out and the A/C would not blow cold? Turned it on and off seveal times and same thing would come on but NO cold air. Then I went to Walmart came out, turned on the AC and BINGO, :banghead:
Cold Air????????? The rest of the day and today, always has had a cold air.
Hope this is not a sign of something coming up down the road.
Thanks for any suggestions,
Rob Roy
shorod
06-07-2008, 11:20 PM
Does your Taurus have the manual (knob) controls or the Electronic Automatic Temperature Control (EATC)?
-Rod
robroy55
06-08-2008, 08:52 AM
Hi Rod, Thanks for the fast reply !! I have the manuel control knobs, If that helps you?
Thanks again Rod,
Rob
shorod
06-08-2008, 12:30 PM
The various doors and flaps in the manual system are vacuum actuated. If there is a problem with vacuum to the system, that could cause what you describe or if the blend door is binding, that could be the problem as well.
Unfortunately these are a bit difficult to troubleshoot when they are so intermittant.
-Rod
robroy55
06-08-2008, 08:22 PM
Thanks Rod !!
All is working good for the past two days so I think I will just not try and fix what aint broke. Thanks as always Rod for your help!!
Take Care,
Rob Roy
