1996 Blazer - HELP!!! on a/c
Google
Web AF
walk_dmc
06-06-2008, 07:52 PM
where is the "under dash fuse board" located. AC compressor has no power.
Scotty89
06-07-2008, 09:21 PM
The fuse box in under the driver side of the dash and to the left of the steering column.
http://www.shopkey5.com/mric/common/asp/Graphic.aspx?MOD=REPTIFF&MODULE_ID=1&SESSION_ID=%7b314C71AD-6AEA-419B-8D4A-FA06F8A3FFA3%7d&IMAGE_GUID=50F06797&PRINT_BW=0&;
THe one your looking for is fuse four. Thats your A/C compressor fuse. From what i have read if this fuse is blown then your daytime running lights wont work, the rear defroster wont work, and your instrument cluster wont work. Just in case i am wrong go ahead and check the fuse. I apologize for the size of the picture. I couldn't get it to shrink.
brcidd
06-07-2008, 10:46 PM
compressor has no power??/ very rarely is it the fuse-- 65% of the time it is a loss of refrigerant due to a leak- system shuts down if not enough pressure to trigger the LPCO switch
Google
Web AF
