Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 06-05-2008, 10:20 PM   #1
ekul55
ekul55 Normal reputation
94 bravada won't start warm
Ok guys, I'm at the end of my rope. I have a 94 bravada vin "W". It started running rough a couple of days ago. When I would try to acceclerate it would jerk until it got up to a higher RPM or unless I babied the gas peddle. NO SES or trouble codes. It got steadily worse until finally it would stall and not start until it cooled down. Then it would drive fine, but after I turn it off it wouldn't start. I replace the fuel filter, no joy. I replaced the fuel regulator and still no joy. I can hear the fuel pump running and if I pour gas into the intake it starts, but I have to pump the gas to keep it running. It seems like a fuel delivery problem, but I don't know where to go from here because it seems to be related to temp too. I've had the plenum off so many times, I can do it in the dark.
ekul55 is offline   Reply With Quote
Old 06-06-2008, 09:52 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: 94 bravada won't start warm
I would start with a full fuel pressure check.
Cold warm and hot and after you drive it 20-30 minutes.
Watch for low pressure or high pressure or a fast leak down.
Post back pressure readings.
MT
MT-2500 is offline   Reply With Quote
Old 08-07-2008, 02:15 PM   #3
ekul55
Whew long delay, but it turned out to be a faulty coil. Thanks for the help.
Old 08-07-2008, 02:33 PM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
You are welcome and thanks for posting back the fix.
Glad you found it.
Good luck
MT
MT
Bookmarks
Google
Web AF
