Unfortunately, if there is no factory connectors with a harness at the location where the lights should be, you may have to make your own circuit with the hardware that comes with the kit. It's not that bad a job to do. You will have to find and/or create a location and/or bracket to install the lights an also hard wire the wires as its own circuit. You don't want to run off of another wire or off of a fuse as this may over load that circuit and create more problems for you than you want. Run the wires from the battery to the switch to the relay and then to the lights then to ground, in that order unless other wise stated on the install directions that come with the kit. Again, it's not too hard. Just don't tap into the vehicles other wires or fuses. It is a fire hazard.
Let me know if I can be of any help, though it is a little dificult when we are on an online chat place. I'll help as well I can any way.
