I HAVE NO BRAKE LIGHTS ON MY JEEP CHAROKEE XJ. I HAVE REPLACED THE BRAKE LIGHT SENSOR AND THE BULDS. ALL THE FUSES R GOOD TOO. DOES ANYONE HAVE ANY IDEA ON WHAT THE PROBLEM CAN BE.
Sounds like you've eliminated everything but the wiring. I'd start at the lights in back, and trace it forward from there. Check especially where the wires run through body panels, that's a ripe area for wear.
Like Fred said: check the wiring, also check to make sure the socket has a god ground or is not rusted inside.
I had the same problem on my jeep. When you replaced the sensor, did you see any loose wires or connectors down by the pedal? Just one wire sill do that. I think theres 4 on the sensor
