Low voltage on gauge 94 Regalbcownie 06-04-2008, 10:00 PM I have a 94 Regal that is showing low voltage on the instrument panel gauge. When I check at the battery while running I have about 14vdc. I can't find a wiring diagram that shows where the gauge is tapped off. Thanks richtazz 06-05-2008, 10:16 AM This is a common issue on these cars, and is a problem with the instrument cluster since a reading of 14V is fine. You may also get a low fuel and/or check guages light also, caused by the same cluster issue. Automotive Network, Inc., Copyright ©2012
