Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 06-03-2008, 06:22 PM   #1
Blutarski
Blutarski's Avatar
Blutarski Normal reputation
Sanity Check Please
My 98 Blazer (4.3L 4WD, Auto, 180k) has some issues suddenly. It runs great, no oil burning, or any of the issues with vehicles approaching 200k. I'm on top of the oil changes, etc. It's got a new fuel pump(a couple of months ago), fuel filter, air filter, and a recent oil change.
It will start fine and randomly will start to run rough, sputtering a bit and power loss, unless you put it to the floor. The engine light will come on at this time and will go away when the sputtering stops. When you stop, it will sound like it's about to stall and smells like sulphur. When driving in this condition, it will puke black smoke (not the too much gas kind). It will also just come out of this suddenly.
I think it's a toasted cat(the original one), but want some input first. We're quite far from anyone that can read that engine code, which, I know, doesn't help, but that's the downside of some privacy, right? Is it worth my cheking o2 sensors? MAF? Fuel filter again? Anything else? or should I just replace the cat?
Thanks again Automotiveforums.com!
-MD
Being Shot out of a cannon will always be better than being squeezed from a tube. That is why god made fast motorcycles, bubba.
-Dr Hunter Stockton Thompson
04 Silverado 2500HD - 98 Blazer - 91 Gti - 95 Guzzi Sport 1100 - 81 Guzzi CX100
Blutarski is offline   Reply With Quote
Old 06-03-2008, 08:54 PM   #2
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Re: Sanity Check Please
The DTC(s) would be very helpful, but if it's flashing, more than likely it will show a P0300 series DTC. If that's the case, AC Delco spark plugs, distributor cap, rotor, and plug wires would be a good place to start, (due at 100,000 miles). The catalytic converter will not cause an intermittent problem, save your money.
old_master is offline   Reply With Quote
Old 06-08-2008, 08:40 PM   #3
Blutarski
Blutarski's Avatar
Thanks for the response.
Well I did the whole tune-up. I had done this at 100k, but you're right, it's due again at 180. The cap and rotor showed enough wear to make me happy that this would be the issue. The right side plugs were VERY sooty, but the left were great looking.
I fired it up and the same old issue, not even a little bit of change.
I found someone who could read the code, and it just said engine misfire. No cylinder number or anything... even with a reset and driving until it happened again.
Sooooo...
I replaced the fuel filter again, plus put in the O2 sensor (that I had already bought) on the right side and tossed a bottle of injector cleaner into the tank and it's healed.
Cool, huh? Although, the engine light came back today, but without the sputtering. Oh well, I'll take what I can get.
Old 06-09-2008, 09:15 PM   #4
duke350
duke350 Normal reputation
With one side plugs sooty and other side ok, might want to pull the plenum off and check for any leaks.
duke350 is offline   Reply With Quote
Old 06-09-2008, 09:18 PM   #5
old_master
Advisor/Moderator
old_master's Avatar
If there is a fuel leak in the plenum, only the center plug will foul due to the location of the drain holes. All three plugs on the same bank fouling indicates a problem with the oxygen sensor.
Old 06-10-2008, 05:50 PM   #6
Blutarski
Blutarski's Avatar
Angry Re: Sanity Check Please
I replaced that one already, and it helped... for a while. After a couple hundred miles of being healed, it's back to the same old act.
Extreme loss of power, in that it will barely climb a hill. Flashing engine light again and sputtering when it comes down to idle.
Here's what I've replaced:
Air Filter
Fuel Filter
Plugs
Wires
Cap
Rotor
Right side o2 sensor
AHHHH!!!!
Old 06-10-2008, 09:25 PM   #7
old_master
Advisor/Moderator
old_master's Avatar
Check fuel pressure and leakdown. Key on, engine off, fuel pump running: Must be 60 to 66psi. After 2 to 3 seconds the pump will shut off, pressure must remain above 55psi for 3 to 5 minutes. Post your results.
Old 06-20-2008, 04:45 PM   #8
Blutarski
Blutarski's Avatar
I tested the fuel system as you suggested (GREAT step by step, thanks) and everything was pretty good. It was about 58-60 lbs on the initial pressure, it would slowly drop to about 54, then stay there forever. When started, it ticks around 58-60 the whole time.
I checked the right side plugs again, still VERY sooty. Not sure if they're at all related, but I checked out the IAC, and the TPS, both are fine.
I'm pretty much out of ideas here... Maybe another fuel filter and Injector Cleaner?
Old 06-20-2008, 08:22 PM   #9
gremlin96
gremlin96 Normal reputation
check the cat on the side that the plugs are getting sooty. the rotten egg smell is a good sign your cat is loaded up.
gremlin96 is offline   Reply With Quote
Old 06-20-2008, 10:07 PM   #10
old_master
Advisor/Moderator
old_master's Avatar
58psi to 60psi key on, engine off, is borderline low. Technically, anything less than 60psi is unacceptable. It will not cause the engine to run rich, as indicated by the sooty plugs. The pressure drop to 54psi is also borderline but holding steady indicates there are no leaks with the pump, injectors, fuel pressure regulator or lines. Connect an OBDII scan tool capable of monitoring the oxygen sensors and MAF sensor. Post the results with the engine at operating temperature and idling steady at 1500RPM.
Hold off on the injector cleaner for now. That system has 6 injectors and the odds of all three injectors on one bank having an irregular spray pattern are astronomical.
Old 06-20-2008, 10:23 PM   #11
old_master
Advisor/Moderator
old_master's Avatar
That is exactly correct. The sulphur smell comes from a rich mixture reacting in the converter, and if left alone, can cause the catalyst to overheat and melt down inside. 95% of the time, the catalytic converter is a symptom, not a cause.
Old 06-20-2008, 11:43 PM   #12
Blutarski
Blutarski's Avatar
I agree, if there was too little pressure, why the excess fuel? Plus, the pump is newish(I know, even new parts can fail). And, Gremlin, this only has 1 cat... I wish it was that straighforward!
I'm really thinking that it's the MAF that I already returned to the store... But why only an issue on one side? I already replaced the O2 Sensor on the right side, with no change in the condition. Here's some more info on the issue:
It takes about 5 minutes of driving to really show up... Right about the time that it gets to operating temp.
There's very little power, to climb a hill for example, in the 1500-3000 range. It will run fine and hold a steady speed at 1200-1500ish, but to accelerate, you need to pound the gas, wait for the black smoke and get it up into the 3k + range. Even then, it's not steady power. You can still feel it's lacking, well, it feels like a few cylinders are just along for the ride. Not really an ideal situation.
Once warmed up, it seems close to stalling when shifting, for example, when backing around in the driveway after a 10 mile drive.
When it gets really bad the SES light flashes.
Also, the right front fender area got crunched pretty good recently. Can you think of any potential for issues associated with that? We're talking fender, punctured battery, bumper, grill, hood... (it's a great wife story that I'll tell over a beer sometime)
Well, thanks for the continued help. I'll try to get that code read tomorrow.
Old 06-22-2008, 08:44 PM   #13
Blutarski
Blutarski's Avatar
So, after driving this thing for a couple hours and putting up with what feels like fouled plugs, it seems to come out of the issue. It's done this twice now. After driving 1 1/2 hrs, about 70 miles or so, it seems to recover. The SES light stays on, and sometimes flashes, but it runs normal. I pulled the plugs again to see and they were all perfect tan instead of sooty on the right side.
Any suggestions?
Again, this is our main vehicle and we're a ways from a shop with all the diagnostic goodies so any ideas, no matter how small, would be VERY helpful!
Thanks!
Old 06-22-2008, 09:43 PM   #14
old_master
Advisor/Moderator
old_master's Avatar
If the SES light flashes, or stays on, there is at least one DTC in memory. Retrieve the DTC(s), and post them here.
Old 06-24-2008, 04:53 PM   #15
Blutarski
Blutarski's Avatar
P0151, P0147 and P0300 Missfire Right Bank
This after a few hours at the dealer, they decided that Injector #1 is toast and #6 is Marginal. They quoted 500 for that job. I found the parts and gaskets for 140, and will jump in tomorrow when they come. Any suggestions, or anything special to keep and eye on?
Thanks,
Mike
Bookmarks
Google
Web AF
