2.2 No start, eating my lunch! HELP!!
flttnd
06-03-2008, 02:41 PM
Hi im new. Let me try & pick ur brain before mine xplodes!!!! 2000 gmc sonoma, 2.2L, automatic trans. Engine replaced w/25,000 mi. motor in Nov. Worked great!! then broke flywheel. Returned to mechanis who installed engine & repaired. As soon as i left started cutting out like running outta gas. noticed smell of fuel & light black smoke. gettin worse since. about 8mpg, no power, blk. smoke on idle, worse if you get on it, which does nothing but slows mph. At a constant speed 45mph if u put it in neutral engine climbs to 3500rpm. in gear rpms fall like cutting out. tapping pedal is only way to accel. Always very rough jumpy idle and almost stalls to leave red lights. wont go over 45 & takes well over 2 minutes to get there. in neutral wont rev above 3000rpm. has never stalled or not started on 1st try. tried spraying tb clealer in it. Engine stalled & has not started since. changed plugs,wires, cleaned iac & egr. removed & cleaned intake, injectors. #2  injectors were dirty. it is getting fuel, and plugs are firing. compression good. pulled valve cover, all good. I have checked vacuum lines, fuel regulator, filter,idk im ready to make a small fire & push her down a cliff!!!! help plz!!!!!!!!!!!!!:banghead:
flttnd
06-03-2008, 02:45 PM
oh yeah Im thinking SABOTAGE by mechanics... They love my money & said it was probably piston rings , but all internal parts i saw looked brand new still. that might help to kno thAT
MT-2500
06-03-2008, 06:29 PM
Ptroper testing by someone that knows what they are doing.
Sounds like you need to find a good repair shop.
Tips on finding a good one.
Check around Ask around
Word of mouth.
Family friends coworkers neighbors business people and delivery people.
Mailmen and parcel delivery people get around and notice a lot of stuff.
Even a good parts house knows what shops are good and not good.
Chamber of commerce and better business bureau and city hall.
If you find a good referral to a repair shop go look them over and talk to them.
Look for a clean looking busy place with nice people running it.
Ask a few questions and ask about their qualifications and training.
Not all places have trained tech/mechanics.
If they do not find a place that does.
Even all dealers do not have all trained techs/mechanics.
flttnd
06-04-2008, 12:36 PM
Thx for the advice, but Ill be taming this tiger myself. I was hoping for REAL advice, which was the reason for posting here in the first place...
flttnd
06-04-2008, 12:42 PM
Anywayz so today I did OBD2 scan & got a dtc for baro manifold absolute pressure low voltage. Faulty map sensor??? replaced & erased code.... still no start. put back in old map same dtc. new map sensor in, should start, right? Also tested fuel pressure, 50psi w ign. on. 55 when cranking. So thats goood rite? Any bright ideas GUYS??????????????
jsgold
06-04-2008, 12:49 PM
I am not familair with your vehicle but let me ask you, how well is it firing?? Can you take the plug wire and shoot fire 2-3" and what color is the fire if you look at the plug? I would remove the coils and igniton module and get em tested as a precaution unless you are getting great firing. That ignition system should fire blue 2-3" period. If not maybe your problem. Just a thought.
MT-2500
06-04-2008, 01:04 PM
The fuel pressure is high.
Specs 41-47. Should be around 45 cranking.
As far a good advice.
I Already gave that.
It needs proper testing by somone that knows what they are doing.
If you are going to DIY it start with the proper testing not throwing parts at it.
Codes do not say sensors are bad.
They say to check them out.
Check
Good spark and good fuel pressure and injector pulse and compression to start with.
Are the spark plugs wet or dry on the end.
Good AC-delco plugs right?
flttnd
06-04-2008, 04:58 PM
Thanx guys. okay so now i ohmmed plug wires all 8.0 -8.2... coils show 6.2 ohms each.Should be between 6 & 30 ohms right? boutta go get dem hoz tested & ignitioin control module to be sure. Let ya kno win i do. Ok now As far as shooting spark 2- 3", yeah, about 1- 2", but looks blueish or white, sometimez orange. the father u hold the plug the weaker it seems. idk... Oh & plugs are AC Delco platinum. They are only slightly wet even after 15- 20 cranking attempts... Does that help???
flttnd
06-04-2008, 06:31 PM
oh so these crackheads at autozone said that the ignition module under the coilpaxx is BAD HMMM. & they said that they couldn't test the coilz??? HMMM.... IDK ?????
DAB77
06-04-2008, 11:06 PM
I could be wrong but I think you may have a plugged catalytic convertor. you can get a gauge to measure back pressure or to do a quick check you can remove the O2 sensor to create an exhaust leak and see if you can get a high sustained rev out of it. normally with a plugged cat the engine will stall if you try to hold a high rev for a couple of seconds.
jsgold
06-05-2008, 01:11 PM
It is rare that the coils would both be bad...usually what happens is that one SIDE of a coil fails and the other fires weakly, so you would maybe have 1 dead cylinder and one weak one at worst. Still should start unless ignition module tests bad. Not a bad idea though to replace them anyway as you would need to later most likely. All should fire strong, no yellow.
flttnd
06-05-2008, 02:38 PM
Thanks for the tips, everyone. About the plugged cat DAB77, I had actually thought about that already & have the exhaust unbolted where it connects to the cat. I just forgot to add that to my list of attempted solutions in my post. Good idea tho....
flttnd
06-05-2008, 03:43 PM
Finally STARTED!!!!!!!!!!!!!!!!!!!!!!! I cannot believe it!!!! Well I'm not too big on taking some idiot's word, working @ Autozone. The guy told me my icm was bad & new one wont be here till tomorrow. So I decided too put the BAD ignition control module back on for kicks... Dat ho fired right up! No problem didnt even hear it crank. Still not running perfect but WAAYYY better. No idea as to the solution or cause of no start, none the less it works. THanks for all the advice everyone!!!
flttnd
06-05-2008, 03:53 PM
Its running. However I would like to get it back to normal. Once it started was not smoking, but after 2-3 minutes, black smoke still coming outta exhaust, which is still disconnected from CAT. Idle still not constant, fluctuates between 800- 1000 rpms. Sounds like its loping... But before it would shake the whole truck and bounce, between 450-1200 rpms at idle. Have yet to road test, to c if it cutz out while at a constant speed. but get up is 95% better. oh no SES on dash or dtc's....
flttnd
06-05-2008, 03:55 PM
wondering if i should still replace Ignition control module. 180 $... But i knew not to listen to those lil queers at Auto parts stores.
adiosk8r91
06-05-2008, 04:12 PM
im thinking maybe corroded <<or how ever you spell it< hoses i had the same problem in my Pontiac try cleaning the intake,checking hoses for holes. just a little tiny hole will make you rpm's cut out like that
jsgold
06-05-2008, 07:00 PM
The ignition module can act up when warm and work when cooled off. Only way is to have it tested, and the coils can have one dead side and a god or weak side. two coils, 4 cylinders. you may have a weak one making it miss, hard to say but that has been my case twice on our cars. You can buy this stuff on ebay cheaper, might check that out. I bought a NEW module with three new coils for less than 70 bucks once, and used ones are sold there too, but you have risk there od course...
flttnd
06-06-2008, 08:27 PM
okay so i guess the whole exhaust is clogged. i tried bolting it back up and cutting out like before. pulled cat whice was black. bought a new high flow and still not right. open exhaust for road test. Much better sum rpm bogging while cruising. threw 4 DTC's tho 2 of each, P0179 fuel composition sensor circut high, & P0113 Intake air temp sensor 1 circut high input. Checking on that. About corroded hoses which hoses, fuel? they are hard lines & i had no fuel pressure bleed-off overnight... indicating a leaky hose. OR do u mean vacuum hoses?? Checked those as well and all were good cept one on TB leading to wire loom on drivers side near firewall in the corner. I replaced it. Please Clarify......... Oh it doesnt smoke while driving. but shopped idling RPMs jump a lil and smokes a lil. Running RICH, i guess. Ill update........
