Service Ride Message
fyguzman
06-03-2008, 11:39 AM
I own a 2001 yukon denali and a "Service Ride" message appear. What can cause that and how I fix it?
Thanks
maxwedge
06-03-2008, 04:10 PM
Welcome to AF, needs to be scanned with a scanner that can access BCM codes, for any kind of diagnosis.
olddriver
06-06-2008, 11:25 AM
check the fuse . it says RTD. that is for the auto ride system. if the fuse is okay, check air lines and compressor (under body passenger side) for leaks or have it scanned if electronic problems.
Shantrane
08-27-2008, 08:14 PM
Its your ride control. It can be many things: Bad compressor, Bad Shock, or a Bad Connection. In my case I had a bad connection. The cap on my front driver side was loose and kept given me the Service Ride ~Control. I pushed down and the light went off but came back on a few days later. I had my auto shop put heat shirk wrap on it and lock it in place! Hope this helps
