1997 gmc jimmy power window problems
dlee3chil
05-28-2008, 02:23 PM
i have a 1997 gmc jimmy that windows wont work and when i try to operate any of the windows the abs light comes on and if the blower is blowing it turns it off, also there a when i try taking the negative cable off the battery it is hot, i also did a ohm check on the negative of the power window circuit breaker and reads zero.
apparently i have a short somewhere but where can i start?
MT-2500
05-28-2008, 04:55 PM
Make sur it is a short.
Run a amp draw amp reading test on it.
A shorted circuit wiil read high amps.
If it is a short start unplugging toll you find it.
Remember a 97 is a bad year on ign switches.
dlee3chil
05-30-2008, 08:05 AM
thanks, i think i found the problem, when i tap on the ignition switch everything works fine windows let up and down and a/c fan works also with no short. so all i need to do now is to replace the ignition switch. hope this help other with the same problems
MT-2500
05-30-2008, 09:42 AM
Look around up in the how to forum.
or get a good service manual.
MT
