Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Buick > LeSabre
Old 05-27-2008, 06:53 PM   #1
ronsaircooled
ronsaircooled Normal reputation
97 LeSabre sucks air through oil fill?
Hi, About a month ago, had the infamous coolant in the oil. I hadn't driven the car too far and one of the replies said to put in oil after the UIM repair (Dorman kit) and crank the engine to push oil through the crank bearings. I let that drain for a week and replaced the filter again. Put in the oil and water and started the engine. It runs fine ( about 200 miles) and no leaks. However, when I remove the oil fill cap, air is being sucked in. If I remove it quickly the engine stalls, removing it slowly, it runs rough, but will run. Also, if I remove the dipstick, air is being sucked in. I don't recall this happening before and I am sure I removed the cap plenty of times when the engine was running? I did not replace the LIM gaskets. Would they cause this condition? Could it be head gaskets or valve stem seals? The engine did not overheat to any great degree. Any help is appreciated, hope the engine is not "fried" . Thanks, Ron
ronsaircooled is offline   Reply With Quote
Old 05-27-2008, 07:28 PM   #2
HotZ28
AF Moderator Elite
HotZ28's Avatar
HotZ28 +50
Re: 97 LeSabre sucks air through oil fill?
Did you install both O-rings on the PCV valve?
“Ye shall know the truth and the truth shall set you free."
HotZ28 is offline   Reply With Quote
Old 05-27-2008, 09:20 PM   #3
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Blue Bowtie Normal reputation
Or is the PCV valve contaminated with the oil "milkshake" and stuck open? That's the likely source of the big air/intake leak into the crankcase.
Blue Bowtie is offline   Reply With Quote
Old 05-28-2008, 03:17 PM   #4
imidazol97
AF -Advisor
imidazol97 Normal reputation
PCV valve with both rubber o-rings.
http://i86.photobucket.com/albums/k1...7/95L36PCV.jpg
imidazol97 is offline   Reply With Quote
Bookmarks
Google
Web AF
