Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Oldsmobile > Intrigue
Old 05-27-2008, 12:37 PM   #1
steffenk
steffenk Normal reputation
Question 2000 GLS 3.5L - recommended power steering fluid
I need to add a small amount of power steering fluid to bring the level up to the dipctick hatchmarks. Any recommendations on what fluid to use?
As far as where it is going, there seems to be a very small leak at the fitting on the pipe to the fluid reservoir. I am hoping that a quarter turn on the fitting will take care of this. I just need to find a wrench that I can fit into the small space.
steffenk is offline   Reply With Quote
Old 05-28-2008, 06:58 AM   #2
Hoppy2
Hoppy2 Normal reputation
Re: 2000 GLS 3.5L - recommended power steering fluid
Look in your owners manual.
Hoppy2 is offline   Reply With Quote
Old 05-28-2008, 05:51 PM   #3
harmankardon35
harmankardon35 Normal reputation
standard PS fluid is fine....you can use dextron ATF as well. I think honda is the only one that specifically requres a certain fluid.
harmankardon35 is offline   Reply With Quote
Old 05-28-2008, 06:17 PM   #4
LittleHoov
LittleHoov's Avatar
LittleHoov Normal reputation
Send a message via AIM to LittleHoov
Yeah, Im currently running a mix of PS fluid and ATF, no issues on my end. I was running low on PS fluid after some maintenance work, and the only thing I had handy was ATF, so in it went!
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
LittleHoov is offline   Reply With Quote
Old 05-29-2008, 12:44 AM   #5
sydtron
sydtron Normal reputation
I can also vouch for the ATF substitution. Having a father who is an Amsoil dealer with many open bottle around the garage also helped that situation along...
"Some men are Baptists, others Catholics...my father was an Oldsmobile man" seriously, my dad sold Oldsmobiles
2001 Intrigue GL
sydtron is offline   Reply With Quote
Old 05-29-2008, 06:26 PM   #6
Jimmy Olsen
Jimmy Olsen Normal reputation
The best thing you can do is use a suction pump and empty the reservoir before adding fluid. I would ONLY use the specified fluid listed in the owners' manual. I won't use ATF UNLESS the manual OK it.
Empty/refill the PS reservoir every year.
1995 Dodge Ram 1500, 101k miles
1999 Oldsmobile Intrigue, 105k miles
2006 Subaru Forester, 33k miles
Jimmy Olsen is offline   Reply With Quote
Old 05-29-2008, 07:05 PM   #7
harmankardon35
i would also reccomend sucking the old fluid out of there with a turkey baster...when i got my car the steering felt a bit resistive and had some pump groan...fluid was jet black and smelled like burnt wires...wich was probably doing about as good of job lubricating the pump as water. I think i used what I had left of some cheap PS fluid and topped it off with some ATF.
Bookmarks
Google
Web AF
