Locking fork dropped off trunk latch lock
JOC Galway
05-25-2008, 08:27 AM
I have a 1977 MGB - the screw that hold the locking fork and the lock cylinder backed out and dropped into the truck - so the trunck is locked from the outside --
Is there a way to unlock the latch fromteh outside - like using a bent wire end or something simialr --
Or do I have to pull the back seat and go at it that way??
any diagram would be helpfull
Thanks
paul J
06-09-2008, 08:51 AM
Thanks
Sir, You mention about pulling out the back seat? MGBs have no back seat! Is your car a MGBGT?
gray gw
06-28-2008, 06:58 PM
JOC Galway
I had the same thing happen when installing a new lock assembly. I removed the backup light assembly and fabricated a light bulb, 1 1/2 or 12 volt, with just wires attached and put it through one of the holes. With a small mirror and coat wire, with a hook at one end , I was able to release the latch.
Hope this helps.
gray gw
