How to fill up transmission fluid on a 323i?BillyFred 05-24-2008, 11:29 PM I decided to change the transmission fluid and once I had it drained I can't find a place to fill it up? Help! Broken-wrench 05-28-2008, 07:00 PM I presume it's a manual transmission? There should be a hex head allen type plug in the side of your transmission. That's wher you would add fluid. You will most likely have to have a pump of sorts to pump fluid from your bottle of fluid into the hole as there is no room to pour it in. If it's an automatic, I have no idea. albertlzr 06-23-2008, 12:41 AM while it is running and cold fill the tarns hole on the side until starts to come out and lock the hole and your ok Automotive Network, Inc., Copyright ©2012
