2003 Malibu abs lightBOOMERBOWL 05-24-2008, 09:06 PM Driving down the road not touching brake. The abs light comes on. It goes off after car is shut off and restarted. You can drive one to five day before it goes on again. Restart and light goes off. Does any body had this problem or knows what might cause this problem? Thank for any help you can give me. slls 05-25-2008, 10:55 AM Sounds like a bad connection, check the wheel sensor connectors. BOOMERBOWL 06-08-2008, 07:03 PM Bad sensor, had to replace hub assembly. mike1981 03-09-2009, 05:10 PM Maybe you took the car to canadian tire? I did to get a new tire, and they cut the abs sensor wire so close to the connector I almost couldn't fix it, I simply soldered the wires together. drvnguy 03-14-2009, 06:21 PM Maybe you took the car to canadian tire? I did to get a new tire, and they cut the abs sensor wire so close to the connector I almost couldn't fix it, I simply soldered the wires together. I have the same problem with my 1998 malibu .sometimes when i hit a bump or just whenever it wants it pops on . can you tell me where this sensor wire is ?, i might take a go at fixing it myself with a soldering gun . Automotive Network, Inc., Copyright ©2012
