01 2.4 to a 03 2.2 motor swapzwergel13 05-22-2008, 08:15 PM im tryin to put a 2.2 out of a 03 alero into a 01 alero will the harness match up.... if so any other problems ill run into? xeroinfinity 05-24-2008, 10:30 AM Welcome to AF. You are going to need more then just a wire harness, they are NOT the same. Plus you also need the PCM, BCM, and I'm sure several other things, not EVEN worth it IMHO. :grinno: zwergel13 05-24-2008, 01:45 PM thank you Automotive Network, Inc., Copyright ©2012
