Re: 96 beretta Rear brakes seems to lock up
Im going to assume that your rear wheel cylinders are not leaking any fluid onto the brake shoes which might give a similar symptom...If the brake fluid has never been changed out I would first bleed out the brakes..dont let the master cylinder go empty with no fluid...then if that didnt solve the problem I would change the proportioning valve if you have one....it might be going bad
