Broken hooks on door panel
Wheel7
05-21-2008, 08:24 PM
Hi,
There are plastic hooks which hold my door panel in place. Some of them are broken off. I did not find them in the bottom of the door. Is there any good way, short of finding another identical panel, to repair this?
Also, the metal clips that hold down the switch panel on the door are missing and the thin plastic they attach to is broken away. I would not want to glue that down-can it be fixed so it is removable later?
Car is 1996 Crown Victoria LX
Thanks
Wheel7
Tuffdrvr88
05-25-2008, 01:54 PM
You should be able to find the door clips at the auto parts store with the screws and stuff. Autozone usually has little spinning racks by the adhesives with nuts and bolts. If they are the ones i think they are you can use the ones from the old ford broncos. As far as the clips for the switch you will have to get creative. Only way to truly fix that is to replace it, otherwise your just going to be rigging it in place. Hope this helps. good luck.
buyadvice
09-10-2008, 01:46 PM
I would request you to visit the site www.fixya.com (http://www.fixya.com).
