01 Ram 1500 5.9 1500 P0171retnavy 05-21-2008, 07:51 PM Recently, my Ram showed a P0171??? New cap, rotor, wires and plugs. Runs good until ya load up the engine. Feels like starving for fuel. Did have miss fire codes prior to new wires plugs etc... Engine idles smooth, like you wouldn't know anything wrong??? Only with engine under load. Can't find any vac leaks. Any ideas??? The Fast Forester 05-22-2008, 01:27 AM I've got an '01 1500 with the 5.9 that exhibited similar symptoms, except I didn't have a check engine light on. Kept getting worse to where I barely had any power driving down the road. Checked the fuel delivery system, it was fine. Pounded on the cat convertor and heard some loose parts in there, took it apart and it was wasted. I'd recommend looking at your exhaust, especially the catalytic convertor. angus10 05-22-2008, 06:03 AM Could be O2 sensor(s) also. And you should check fuel pressure and flow. But with the way these things eat converters I agree that you need to check it. retnavy 05-22-2008, 08:56 PM Check fuel pressure, had 46-48 psi in gear and a/c running. No O2 sensor codes. Problem is intermittent and seems to happen after driving for a while mostly highway. Hasn't given me a problem today, had a convertor problem on my last 94 Ram.???? angus10 05-23-2008, 06:11 AM You should check the converter then. Sometimes after they heat up and expand, things can move around inside. elite1msmith 07-08-2008, 08:16 PM any fix on this? Automotive Network, Inc., Copyright ©2012
