Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > BMW > 7 Series
Old 05-20-2008, 02:14 PM   #1
RikH_96
RikH_96 Normal reputation
Dead Battery & opening door
I have a 1996 750il... Recently I had my battery go dead (the car had been sitting for 6 weeks while I was away). When I tried unlocking the driver door manually it wouldn't open. I could get into the trunk using the key... Once I hooked up the battery charger I could open the driver door using remote & manually... Is this normal? Also, I didn't have my plastic key with me but, would IT have opened the driver door when the battery was dead?
BTW... Great Forum
RikH_96 is offline   Reply With Quote
Old 05-21-2008, 11:33 AM   #2
lincolnmaster80
lincolnmaster80 Normal reputation
Re: Dead Battery & opening door
It is normal for a battery to go flat on one of these things, especially after a month and a half, as some devices still remain active, like the immobilizer for instance.
If you couldn't get it open via the manual way, try the other front door, as sometimes it'll work on one side but not the other.
If your battery was going flat on a regular basis, like if you let it sit for a day, then you might want to replace the ignition switch as that is usually the common culprit for battery drain. A failed switch won't shut off properly leaving more devices on than it should.
As for your plastic key, not completely sure what that is...
1990 E32 750iL --> Pictures
Production: 02/1990
Johan and Sean's E32 Page - Repairs and How-to's
E38.org - Information and tech tips for BMW's
Shogun's E32 Tech-Tips
Gale's Repair Page
ETK Online
lincolnmaster80 is offline   Reply With Quote
Old 06-04-2008, 07:20 PM   #3
Bear
Bear
I have heard of people connecting a booster battery to the license plate light ad that gave enough power to open the door locks. Also hooking a battery to the starter (large cable and ground). On my '88 750 I made a manual release cable by taking braided wire, looping it around the hood release cable right at the forward release jaws and then routing it out near the drivers side headlight (with a finger loop).
Bear is offline   Reply With Quote
Bookmarks
Google
Web AF
