Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > MR2/MR-S
Old 05-18-2008, 12:31 PM   #1
redmr291
redmr291 Normal reputation
coil igniter
my igniter started to fail some days ago and i remember that i had the old one from the 2.2 so i plugg it on it plugg perfectly and started like nothing but later in a half an hour or more the car start to fail again untill it turns off i started again and it turns on but turns off few seconds later and black smoke comes out well i think i did wrong connecting the other igniter but now i dont know where to find a good igniter for sale
redmr291 is offline   Reply With Quote
Old 05-22-2008, 06:42 AM   #2
GeoffBooth
GeoffBooth Normal reputation
Re: coil igniter
What makes you think it's the ingniter? I had one fail, made the engine crack and bang, firing all over the place all the time. This could be the ignition module. Don't know about the black smoke though, could be unburned fuel causing this, is it backfiring?
GeoffBooth is offline   Reply With Quote
Old 05-22-2008, 11:31 PM   #3
C_a_R_f_R_e_A_k
C_a_R_f_R_e_A_k's Avatar
C_a_R_f_R_e_A_k Normal reputation
Re: coil igniter
check fuel regulator, check the coil, check the pickup in the distributor, the ignitor is the module, also check for good grounds or erratic grounds that break contact or make poor contact when they get hot
C_a_R_f_R_e_A_k is offline   Reply With Quote
Old 05-24-2008, 09:20 AM   #4
GeoffBooth
Re: coil igniter
Ok, I learn something new every day. The box of tricks a top the coil is the ignition module. I thought the pickup in the distributor was the module due to the fact they are expensive items.
Old 08-18-2008, 12:49 AM   #5
sp55b
sp55b Normal reputation
Re: coil igniter
My car has the some problem and I was wondering if you had found a solution yet? I had changed the coil already and I have not changed the ignition module. Was this the solution?
sp55b is offline   Reply With Quote
Bookmarks
Google
Web AF
