Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Hyundai > Elantra/Avante
Old 05-16-2008, 05:46 PM   #1
Paoth
Paoth Normal reputation
Odd Power Loss
Hello,
I have a '01 Elantra with a manual transmission and roughly 60k in mileage. I recently started experiencing power loss in all gears including reverse. What happens is when I press on the gas it seems that only some of the power is actually being used. Basically when I press on the gas pedal once it goes past a certain point there stops being an increase in acceleration and just an increase in RPM. Has anyone ever heard of this happening or know what the cause may be?
Thanks.
Paoth is offline   Reply With Quote
Old 05-17-2008, 12:00 AM   #2
The Fast Forester
The Fast Forester's Avatar
The Fast Forester Normal reputation
Re: Odd Power Loss
Might have an exhaust problem, is your check engine light on and can you pull a problem code if so? Could be oxygen sensor issues or bad catalytic convertor. If those are ok you might want to check the fuel delivery system...injectors, filter, etc. How about a tune up, had one lately?
The Fast Forester is offline   Reply With Quote
Old 05-23-2008, 05:18 PM   #3
peachferrari
peachferrari Normal reputation
Re: Odd Power Loss
So the revs go up but the speed doesn't go up with them? Sounds like the clutch is slipping.
2005 Tiburon SE 2.7L V6 6sp manual
2008 Santa Fe Limited AWD, 3rd row, Nav
peachferrari is offline   Reply With Quote
Old 09-25-2008, 08:11 AM   #4
jsinton
jsinton Normal reputation
Re: Odd Power Loss
Try to bleed the hydrolic system first and determine if the clutch control arm is working properly. Might save you a lot of money or time.
jsinton is offline   Reply With Quote
Old 06-18-2009, 08:31 AM   #5
pamselantra2001
pamselantra2001 Normal reputation
Re: keyless entry pad
hi all ,this may of been done already,but im new and not shore how to find it .know my keyless entry pad is stuffed . i was at the wreckess and found another .now is there anyway of making it work with my car,does anyone now how to try or direct me to the page .cheers
pamselantra2001 is offline   Reply With Quote
Bookmarks
Google
Web AF
