Re: starter location 99 intrigue 3.5
You will also need a good, reliable way of getting the car a decent distance off the ground, and supporting it properly once its there. If you have a set of ramps this might be the time to use them.
You can use a jackstand on each side of the car, but I would just barely have room to mess with the starter using that approach, Im pretty skinny and I felt cramped when I was exploring under the car.
Whatever you do, double and triple check it, and maybe add an extra jack or two for backup. Youll be laying with pretty much everything from the waist up underneath an Oldsmobile, you dont want any problems eh?
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
