Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 05-07-2008, 05:12 AM   #1
NANAROYAL
NANAROYAL Normal reputation
Tapping Noise
I really hope someone can tell me what to do. MY 2002 Grand Am is making a tapping noise when the car idles. The car is running ok. no other problems that I'm aware of..... But I'm worried about this......... HELP HELP HELP
If anyone can help please do...........THANKS
NANAROYAL is offline   Reply With Quote
Old 05-07-2008, 06:25 PM   #2
xeroinfinity
out saving the world
xeroinfinity's Avatar
xeroinfinity Normal reputation
Re: Tapping Noise
Welcome to AF.
What size engine ??
1999 Grand Am SS & Grand Am GT 3.4 OHV
Who'd ever thought the "G" in GM would stand for Government Motors.
xeroinfinity is offline   Reply With Quote
Old 05-18-2008, 04:44 PM   #3
grandgt01
grandgt01 Normal reputation
Re: Tapping Noise
if its a 3.4 liter its the lifters thats a common problem with grand am 3.4 liters
grandgt01 is offline   Reply With Quote
Old 05-18-2008, 10:10 PM   #4
Gir-_-
Gir-_-'s Avatar
Gir-_- Normal reputation
Send a message via AIM to Gir-_-
Re: Tapping Noise
could very well be the belt tensioner, Im facing this issue at the moment
99' GRAND AM SE V6H.O. 188fwhp and climbing!
Gir-_- is offline   Reply With Quote
Old 05-19-2008, 08:29 AM   #5
xeroinfinity
Re: Tapping Noise
I have not heard a belt tensioner tap or tick... The pulley can make a grinding sound, as with the power steering pump too.
Lifters are a problem area, which in turn causes the valves not to open properly and it will cause other noise.
My GA GT(3.4) is getting ready to be pulled apart because it has a couple lifters ticking.
Realy sucks , cause I just had it apart not long ago replacing the head/LIM gaskets.
Old 05-19-2008, 04:10 PM   #6
J-Ri
J-Ri's Avatar
J-Ri Normal reputation
Re: Tapping Noise
To find out what part it is, use a long screwdriver as a stethoscope (or buy an automotive stethoscope ~$20), just put the handle to your ear and probe various parts of the engine until you find what's loudest. Just pay attention to moving things like the belt or fan(s), I thought I was going to lose my hearing when I got my stethoscope into a metal fan blade.
I have heard a tensioner make a tick/tap sound. If it starts to twist sideways (pulling outward at the pivot point) it can move back and forth and make noise when it hits.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
'86 3/4 ton Silverado
350 V8, 4x4, 4" lift, 1 ton axles swapped, converted to 4 wheel disc
35" BFG Mud Terrain T/As
Shortened to 109.5" wheelbase for those tight trails
http://www.boycottpepsico.com/default.aspx
You see "Fresh oil, loose gravel"; I see "Free undercoating"
J-Ri is offline   Reply With Quote
Bookmarks
Google
Web AF
