Strange grinding noise in 1st gear...AlwaysMovin 03-04-2003, 07:46 PM While taking off, toward the upper part of the RPM band I hear a stranger grinding / clunking noise coming from the tranny. After I shift into second the noise goes away and this only happens in 1st gear. Any ideas? I have a shoft through shifter and I have bumped the shift linkage on a speed bump before (but who has not done that.). I just need to know if I should be worried. Thanks. :) crxlvr 03-04-2003, 10:51 PM its prolly your first gear is just grindin some teeth. B16EJ1 03-04-2003, 10:59 PM If that's the case. It's time for a swap.:D AlwaysMovin 03-04-2003, 11:02 PM Thanks for the help, I'll have to check this out next time I do the clutch. :) civickiller 03-05-2003, 12:35 AM umm try and get your tranny fluid changed, it might help. its cheap too Automotive Network, Inc., Copyright ©2012
