Re: Interior lights don't go out
It does have the body control module.
Here's the way I think it works.
Each door has a latch switch that tells the module if the door is fully closed. If the car has the door ajar warnings then you can tell right away if those switches are working. The front doors have switches on the handles that tell the module the door is being opened. The BCM has a diagnostic mode that that will bong when the handles are pulled & bong again when released.
If all the door switches are working properly than you can eliminate the RFA module by unplugging it from the BCM. If the lights turn off the RFA module is bad. If the lights stay on then the BCM is bad. Again, that's the way I think it works.
