Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Kia > Sportage
Old 05-04-2008, 06:55 PM   #1
jinx10000
jinx10000 Normal reputation
Vibration on Acceleration and Coasting in High Gear
Kia Sportage 2001 4 cylinder
Little over 100,000 miles.
Manual Transmission
The Kia has recently developed a large vibration. It is most noticable when accelerating and when coasting in fifth gear. It seems to be originating from the rear of the vehicle. Cannot be 100% sure of that. Feels like it is causing a drain on the power. Anybody have any ideas?
jinx10000 is offline   Reply With Quote
Old 05-05-2008, 04:44 PM   #2
jinx10000
Re: Vibration on Acceleration and Coasting in High Gear
More information.
It seems to be the most noticeable in third and fourth gear in a slow acceleration. Sounds somewhat like a car with loose items and a long continuous bass note from large speakers.
Old 05-07-2008, 10:32 AM   #3
LMP
LMP's Avatar
LMP Normal reputation
Easy things first: drive shaft U-joints. Mine had it on the front last fall...would show only in 4WD then , of course.
I don't believe in miracles.
LMP is offline   Reply With Quote
Old 05-08-2008, 06:09 AM   #4
jinx10000
Thanks for the help. I am starting to believe it may be an engine problem. I had to sit in idle for awhile yesterday and I noticed that every minute or so the engine would start running rough. It is not continuous, or I couldn't feel it continuously. I thought this may be causing the vibration by uneven power at the wheels. Any ideas what would cause inconsistant engine trouble, that seems more noticeable when there is a strain on the engine?
Old 05-08-2008, 02:10 PM   #5
LMP
LMP's Avatar
..?? is the Check Engine Light ON? Misfires are a common plague on this car..maybe because of the heat containment around coils and wires...and codes come as P0301/2/3/4, depending on cylinder...
Old 05-09-2008, 05:51 PM   #6
jinx10000
No the check engine light is not on. I changed the spark plugs and wires.
Old 07-05-2008, 03:05 PM   #7
jinx10000
This problem did in fact end up being a bad U-Joint for anyone else that experiences a weird vibration. I must have read right over LMP's first great advice.
Bookmarks
Google
Web AF
