My dad parked his 02 Sonoma after it ran fine. Tried to crank it that night, and it would turn over but refused to crank. Today I checked with a spark tester and we were getting the light on when the plug would fire, but it seemed somewhat dim (maybe just me, can't recall how bright it should be). Checked fuel pump...had good pressure. Chjecked fuel filter and seemed clogged/restrictive. Bought another one, still won't crank. Checked exhaust...no problems there.
Crazy thing is while it's turning over, it seems every now and then to 'bog' like something's mechanically holding the crankshaft back.....then releases and bogs again. Even with my Ranger next to it running with jumper cables keeping his battery up. We finally tried cranking it so much that smoke rolled out of the starter motor.
My question is.....is it the starter doing all this, or did we maybe burn the starter up due to an underlying problem? We took Serp belt off and checked all pulleys and turned motor over with just the crank being turned and it still bogs. Anyone got any ideas?............it'll be Monday or so before he gets the new starter. I just wonder what it could be if it still won't crank. Thanks.
