1997 ram1500 coolant leak help
civictypr
05-03-2008, 10:15 PM
I have a 97 ram with the 5.9L. I have a coolant leak from the back side of the engine dripping of the transmission bell housing. I did the upper end gasket kit, for the intake. After doing so its still leaking and I cant see from where. Its dripping from the trans bell housing. Im super frustrated and any and all help would be gratefull
Tuffdrvr88
05-23-2008, 03:14 AM
Have you checked to see if you have a leaking hose going from the front of the engine back to the heater core in the firewall?
rhandwor
06-26-2008, 06:42 PM
You need to go to a carwash with a high pressure hose. Clean it off good.
Lay on top of the engine with a flashlight and inspection mirror.
You should be able to see it. Look along the back where the head gasket is.
Also look over the intake for a leaking fitting of some kind.
