94 accord Q
cbr310
03-04-2003, 03:32 PM
how do you know if you have abs?
thanks
MAtt
Wiseguy
03-04-2003, 08:30 PM
look under your hood, do you see a little black box that say "abs motor relay?" its by the fuse box, if you have one you probably have abs
Frenchbulldog
03-04-2003, 11:34 PM
slam on the brake pedal when going slow like 15-20 mph if the pedal "chatters" you have ABS
KrNxRaCer00
03-04-2003, 11:51 PM
haha...i like the "check under ur hood" response more. easier, an doesn't waste the breaks...u should also have a lil light on ur gauge cluster that blinks "ABS" or lights up w/ that when u 1st start ur car if u do. which model u have? cuz i kno LX/DX doesn't have ABS.
Frenchbulldog
03-05-2003, 08:43 AM
yes racer you are correct, something else to consider early abs systems in hondas had failed(locking) modulator valves so the pedal test also tells you if the system is working.
darth1sbw
06-22-2003, 01:25 AM
i have a 94 accord LX with ABS......
neunan
06-22-2003, 06:27 PM
you could also just look behind the wheels. if you dont have ABS there will only be one line (brake fluid) going to the calipers, if you have ABS there will be another going to the...um..modulator? the ABS thing.
point is, 2 lines for fluid = ABS, 1 line = not.
