About to change Hub Bearing Torque spec?
Google
Web AF
dizzle1
04-27-2008, 10:15 PM
I brought a new hub bearing today for the FR of my 00 intrigue it was making noise for months. I changed both of the front hub bearings myself in 10/05 but the front right went out again. The new one didn't come with any instructions does anyone know the center nut torque specs?
1st untorque center nut, lugnuts,jack up car
2nd brake caliper nuts, then hang it and tie it, I did to the spring, slip out rotor
3rd big bit torque wrench it out
4th unclip abs sensor
5th take off the 3 bolts on the back of the hub bearing guide wire out the spindle make sure the metal bracket for the sensor isn't bent or it will scrape the inner side of your rotor
That should be it I think then vice versa
34mm-35mm,19mm,15mm,13mm
Will Help
04-27-2008, 11:11 PM
118 ft lbs torque.
dizzle1
04-28-2008, 08:25 PM
Changed it problem solved took 2hrs had to sand off rust and dirt
Google
Web AF
