Re: 76 pontiac 400 swap
MAYBE. Depends on when the '76 was built. Early production had some of the leftover '75 blocks.
If there are 5 mounting holes drilled and tapped on each side, it will fit fine. If there are only three, you'll need an adapter "kit". Those are available from either Performance Years or Ames Performance and relatively cheap (about $35). Not a big deal, but a little one... (:- everything else will fit. Use the exhaust manifolds from the '67.
You understand, the '76, if stock, won't TOUCH the '67, right? Do you still have the '67 engine? You would be better off rebuilding that. DO NOT throw or trade it away... If you want to part with it, PM me.
Jim
