| Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here. |
04-25-2008, 08:44 PM
Piston Slap
guys with ls1s... i love my 2001 z28. but after discovering that little noise i heard was piston slap (apparently a problem ls engines are notorious for), i was horrified. i thus began thinking i have to trade it off before it tears up. i'm running 10w30 syntec in it. still hear the noise. is this a major problem? should i trade it for a mustang gt?
04-25-2008, 09:51 PM
Re: Piston Slap
Mustangs are girl cars, with the exception of the 67 SHELBY GT500. Can't say anything about the piston slap thing, but if it does eventually put you in the market for another vehicle, just get another camaro/firebird. You probably won't have the same problem again.
1989 Firebird 2.8l V6 Red and White w/flames. Stock. Daily Driver.  197,000 miles, will it make the 200K mark? Who knows? Almost as many starters as miles
1967 Firebird 400 V8 Convertible. Primer Grey with green bondo spots. Cam, Headers, Dual Exhaust w/glasspacks, larger valves, 4bbl carb. TH400 w/ Shift Kit. My dad's ride, but will be mine someday.
Mileage unknown, doesn't have original speedo, switched the 120 for a 160.
04-25-2008, 09:56 PM
Re: Piston Slap
i've done my homework online about piston slap in ls engines. i just wish i had done it BEFORE i bought the car. it is VERY common (apparenly, google) i have had a 1985 2.8 firebird, and a 1992 305 firebird. i would say i've been pretty loyal. but when i want to empress my buddies with my new car and we hear CLANK CLANK CLANK, i'm not too cool. still, it runs like a mofo.
04-26-2008, 01:57 AM
eBay aDdict™
Re: Piston Slap
From what I've heard, you should only hear the piston slap noise duing the first few minutes of warm up. Once the engine is up to normal operating temperatures, you should no longer hear it. If you do still hear it even after driving it around for some time, then I would imagine something must be wrong.
- Jason
1995 Pontiac Firebird ..........................1995 Geo Prizm
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
04-26-2008, 03:42 AM
Re: Piston Slap
 .....that is all.
04-26-2008, 08:55 PM
Re: Piston Slap
Originally Posted by 72chevelleOhio
thanks for your help, man.
04-26-2008, 10:50 PM
Re: Piston Slap
04-26-2008, 11:56 PM
Re: Piston Slap
I had (note "had") all the symptoms. The pistonslap.com website is almost like a bow-tie block hater's site. Lawsuits and all that jiminy.... PS.com put out GM's tech bulletin, which goldz28 listed above, and some tips on how to fix it (ironically enough).
One thing that wasn't listed anywhere that seemed to fix mine, was just a simple seafoam. I had my knocking sound worse than ever and it was time to run the ol' seafoam. Stopped, ran a good bit of it through. Hey, no more ticking! I haven't heard it once since I ran the seafoam through. If you haven't tried that yet, I would suggest giving that a shot.
Any questions, just IM me or PM me... IM me at drivenbychange on AIM or takenbythedarkness on Y! msgr.
04-29-2008, 11:18 AM
Re: Piston Slap
Originally Posted by ZXeno
I had (note "had"  all the symptoms. The pistonslap.com website is almost like a bow-tie block hater's site. Lawsuits and all that jiminy.... PS.com put out GM's tech bulletin, which goldz28 listed above, and some tips on how to fix it (ironically enough).
You apparently had carbon build up in the combustion chamber. Regular use of Top Tier Gas should keep that from happening again. http://toptiergas.com/
Retired and Loving It!!! 33 years with General Motors Product Service Engineering. A.S.E. Certified. You can fix ignorant but stupid will be a real challenge!
