Question about door panel cracks2000TAinNE 04-24-2008, 12:21 AM I was wondering about interior pricing as well. Let me back up a second though....does anyone else with a Firebird/Trans-Am/Camaro have the little cracks in their door panels at the top about 3/4 of the way back? I have heard that is a common issue. Please tell me I'm not the only one. Both freakin door panels did it to me in the same damn spot. So, my question is....does anyone know where to get the door panels for less than $350 each? I have been looking all over the web, and ebay, and no one that I found is selling for less than $350 each. Help! Earlsfat 04-24-2008, 09:59 AM So, my question is....does anyone know where to get the door panels for less than $350 each? I have been looking all over the web, and ebay, and no one that I found is selling for less than $350 each. Help! Guessing from your handle that it's a 2000 TA??? Try a boneyard??? If you're looking for something new, forget it, you're gonna pay a boatload. If you're looking used, try Ebay, local boneyard, etc. I have a 70... it has holes and cracks everywhere :disappoin . As soon as I get done with teh engine rebuild etc, I'm starting on the interior - with fiberglass :iceslolan . 2000TAinNE 04-24-2008, 05:27 PM I did find a guy on ebay that is selling a set for $450 but he speaks very bad English and I don't know if they have the clips, are new, or what. Thanks for the reply though, and yes, it's a 2000 Trans-Am. http://members.cox.net/eyezburnin/cars/008.jpg blindeyed 04-25-2008, 03:07 PM 200TAinNE, I moved your posts from the other thread and started you a new thread. The other thread was fairly old, but I wanted to address your concern. Any door panel from 98-02 will crack. It doesn't matter if it looks pristine at the time you buy it, it will crack. There are 2 easy remedy's to this. You can buy some 93-97 door panels from the junk yard for fairly cheap, since these have not shown to crack at all like the 98-02's. Or, you can follow this guide on how to repair your door panel. Though, if it's cracked all the way from the top to the bottom, it's a lost cause. With a lot of people dealing with this problem I thought I should post the writeup I did for collectorfbody.com. Its very straightforward and basic, geared toward the novice. I myself had never done any sort of repair like this on the car myself, but I was damned if I was going to let it get worse, haha. Late in 05 I noticed that my Driverside Door panel was getting the infamous crack in it that so many get. Here I thought I would post how I went about fixing it. First thing is you have to get a few supplies: One being a Plastic adhesive. I got this one at Walmart for like $3. http://www.legendoffire.com/collect/up-down/doorrepairA.JPG You're also going to need a touch up kit for the panel itself. Depending on the severity of the crack, results will vary. I got this kit for about $8, again from Walmart. http://www.legendoffire.com/collect/up-down/doorrepairB.JPG First step in the removal is to take off the Switch Panel. The Panel is held on by tension clips(the black steel clip at the top of the panel). All you have to do is pull up on it and it will come free. Be sure not to pull too hard, though as you don't want to stress the wire harnesses. http://www.legendoffire.com/collect/up-down/doorrepairC.JPG Next, just disconnect the wiring harnesses from the Switch Panel and set the Panel aside in a safe place http://www.legendoffire.com/collect/up-down/doorrepairD.JPG Now for the removal of the screws holding the panel in place. The first is the one in the center of the door handle coverpiece. Do not remove cover yet. http://www.legendoffire.com/collect/up-down/doorrepairE.JPG Now, before you try to remove the cover you have to take off the lock switch knob. You have to pull the end out toward you for the tip to come off the wire. It may take some strenght to pull it off but it will be fine. http://www.legendoffire.com/collect/up-down/doorrepairF.JPG Here you can see how the wire is and what the plastic piece actually sits on. http://www.legendoffire.com/collect/up-down/doorrepairG.JPG Carefully pull the cover piece off from around the door handle. Do so slowly as there is a bulb attached to the pice that must be unplugged. Just unclip it and set aside the cover in a safe place. http://www.legendoffire.com/collect/up-down/doorrepairH.JPG The next screw to remove is down in the map pocket of the door. http://www.legendoffire.com/collect/up-down/doorrepairI.JPG Next, remove the screw from the very Front underside of the armrest, near where the switch panel is. http://www.legendoffire.com/collect/up-down/doorrepairJ.JPG Remove the screw that is located near the now exposed area of the door handle. http://www.legendoffire.com/collect/up-down/doorrepairK.JPG Remove the cover for the Side mirror access. This will allow easier removal of the door panel. place the cover in a safe place after removal. http://www.legendoffire.com/collect/up-down/doorrepairL.JPG The next Screw can't be seen easily in the photo but it is in the exact center. There is a hole where the armrest meets the map pocket and inside is the screw you need to remove. http://www.legendoffire.com/collect/up-down/doorrepairM.JPG Now for the removal of the panel. I wasn't able to take pics of this process due to the fact that I need both hands to remove the panel. Now, the only thing holding the panel onto the door is a bunch of plastic downward facing hooks. Remove the panel by gently pulling it up and towards you at a slight angle from the door. While removing the panel it may seem to get stuck, just pay attention to the area that the hook are in as the toughest ones are near the front of the door by the speaker. Be careful pullin on it due to the fact that the front speakers are still connected to the panel. Once you have the panel semi removed you can disconnect the tweeter and speaker. Once the panel is off you will be able to see the problem. The crack is caused by a structural flaw in the plastic combined with the use of industrial staples to hold the window trim to the panel. The crack is cause by changing weather temperatures which make the plastic panel expand and contract. The window trim has a metal insert which does not allow for any kind of expansion or contraction. and since the plastic is mated to the strip with thick metal staples...it doesn't allow for the panel to stretch are release naturally and causes the panel to pull itself apart.' http://www.legendoffire.com/collect/up-down/doorrepairN.JPG What you need to do is remove the staple in front of the crack area and all the ones behind the crack area. http://www.legendoffire.com/collect/up-down/doorrepairO.JPG I used a flat head screwdriver and needle nose pliers to remove the staples. Bend the teeth straight and then just push back through the plastic to get them out. http://www.legendoffire.com/collect/up-down/doorrepairP.JPG Once the staples are removed the panel will come back together naturally. Depending on the size of the crack you might need some pressure to really hold it together. scuff up the area of the crack nicely for the adhesive to bond to. http://www.legendoffire.com/collect/up-down/doorrepairQ.JPG Next follow the directions to mix the Plastic Welder and while the crack is nicely snug, apply a generous amount of the welder to the area you sanded. The adhesive should dry according to the directions and once that is done you want to replace the staples. I used some copper wire that was a bit smaller in diameter than the staples. This will allow the panel to move a bit against the window trim. I just put the wire through each hole as a direct replacement of each staple and it worked fine. http://www.legendoffire.com/collect/up-down/doorrepairR.JPG I used Interior Vinyl/Leather Repair Kit that can also be bought at Wal-Mart for very little money. Comes with many colors to use to mix to match your interior. If you have a color other than black, I would suggest mixing the color per directions on the package and then testing it agains the BACKSIDE of the panel. Let it dry and see how close it comes to the panel color. The exterior of my panel only needed a dab of black touch up paint. The crack repair is in the exact center of this photo. http://www.legendoffire.com/collect/up-down/doorrepairS.JPG Now with your newly repaired panel...just reverse the deconstruction process from above and replace the panel. Be sure to hook up all speaker and lamp wires while doing so. Now, my passenger side had no crack. As a preventive measure, I took it off too and reinforced the "crack sensitive" area the same way I did the driverside. When I took the panel off I could tell that there was stress being put on the section of the panel that cracks, but had yet to actually crack. If you don't have any cracks...I still suggest reinforcing this area. Its better to be safe than sorry. Hope this will help out anyone looking to do the repair themselves. It is really not that hard as long as you take the time to do it slow and careful. I do not take credit for this guide, as it was posted by member BANDITCAR of LS1Tech. '97ventureowner 04-25-2008, 03:19 PM Another online source for interior door panels is www.car-part.com. You enter your vehicle's info and select from a drop-down menu the part you are looking fr and click submit. You then get page(s) of results from salvage yards across the country with info on price condition and many times, color. The salvage yard's info is also there so that you may contact them w/ question sand shipping info. You can even refine your search to areas closer to you. I have a '95 Roadmaster, and these cars are notorious for cracked interior panels. We are in the same boat as you are in trying to find suitable replacements. I have found panels for my Roadmaster on that site where I couldn't anyplace else. 2000TAinNE 05-03-2008, 01:54 AM Thanks for the help. Much appreciated! Automotive Network, Inc., Copyright ©2012
